I can't make such copy with the latest ver of DT Pro! I'm trying to backup HellForces [CD 1] but no matter what profile/settings are used I still get the message "Disc image dumping failed, make sure you've selected correct profile". Used every software: Alc, Blindwrite and VCD 10 and still the image isn't accepted. And daemon even can't make a copy! My drive is Optiarc DVD RW AD-7191A. I always managed to create a working backup with this drive (Securom all version, Safedisc, Tages and etc) but it's the first time I had no success. Or Laserlock has sort of a blacklist? Help needed BADLY!!!
Anyway to backup a Laserlock protected disc?
As you've already tried the recommended apps you maybe should try with another drive - if available.
But before that please retry to launch with your image(s) with LaserLock emulation
activated (Tools/Preferences/Advanced).I'm not employed by Disc Soft and my views do not necessarily reflect the ones of the company.
