'ello...
just joined the forums and had a quick question.
I am currently using Daemon Tools with Madden 2004 and the patch thats version v4.1.1.0 (i believe that is the correct version). I was just wondering if the new patch checks for the CD in a different way that would break what I'm doing. I would rather find out instead of breaking it and having to uninstall/reinstall. Thanks for any info you can give me.
