Can't enable advanced preferences checkboxes
  • Can't enable advanced preferences checkboxes
    Hi, i just installed daemon tools pro advanced and someone told me to run i game i need to enable the checkboxes in tools - Preferences - advanced. When i click on it i cant enable any of these boxes. They are all faded somehow.
    anyone know why this is and how i can fix this?
    You have to install SPTD.
      Thanks for your quick reply but I have done what you said and it only asked me to update, so STPD was already installed. In wat map do I need to put it? i putted it in the daemon tools map as you can see. But thet checkboxes are still faded. Could it be anything else, or am I doing something wrong?
        When i klik on thee sptd file it says it can only update because its already installed so i clicked on update and placed the sptdicon in the daemon tools folder like this:
        But it did not solve the problem, the checkboxes are still faded.
        Am i doing something wrong ore is there something else that i can do?
          Which security software(s) are you using ?
            Avira AntiVir personal
              You actually added a virtual SCSI/IDE drive?
                ok, now i can check the checkboxes but when i pres adjust and ok. the selected boxes just go back to empty after i selected ok
