Hi Gang,
I've used Daemon Tools for some basic creating and mounting of images etc. for several years but I have a question regarding "true" DVD simulation.
Here's why. I am a multimedia developer and I'm testing a DVD authored in Flash and it runs fine from the hard drive or a USB stick but when I burn an actual, physical DVD it behaves differently. Every time I have to test a fix I need to burn a new DVD which is naturally a pain.
So I thought I would just create an .iso image from NERO instead of actually burning the DVD, mount the image then test from the mounted image. Much faster right?
Well the program runs fine from the mounted image as it did from HD or USB stick.
The application ( which needs to run standalone from a DVD) only misbehaves when it runs from an actual physical DVD disk.
So the question is ...
1) Can Daemon Tools truly simulate a DVD disc?
2) Is there a special setting I need to use? (I looked at drive info for the mounted .iso ... what is Cooked Read Mode?)
3) Do I need a different app altogether to do what I want.
Thanks in advance,
Crane
Thanks in advance,
Crane
