Hi all,
I have a problem with softwares and I search some help here
1) I make my image with Clone Cd. Succesful
2) I open my image with WinIso. Succesful
3) I add my directory for add some exe files or updates. Succesful
4) I open my image with Daemon Tool for check. Fail
When I go in the directory, EXE files appear like some bad files and when i try to execute them, Windows said me "It's not a W32 application".
And this error appears for all image.
But when i burn this image, the game work perfectly. The installation is good but I must go each time on the Internet to take files. It's very bad.
Please help me if you can.
Sorry for my quite english but I'm french.
Thanks you a lot
Thanks you a lot
