Warcraft 3 CD probs
  • Warcraft 3 CD probs
    Okay, my Warcraft 3 cd will not run as long as Daemon Tools is installed on my computer?
    I get the "PLz. insert Cd message" if I uninstall Daemon Tools it will run.
    Any suggestions, pla. this is reakly annoying?
    Which Daemon Tools version do you use?
      The latest one I saw, 344 i think
        Which OS do you use, and do you use newest patch 1.14b?
          XP and yes
            Check if it works if you enable SecuROM emulation.
              i got the same problem and i tryed the secuROM emulation
                Do you have AnyDVD installed?
                  If you're running the Frozen Throne expansion you'll need to extract a data density file from the CD, eg. a BWA file with BlindWrite Suite. If you're trying to play Reign of Chaos, a normal image should work without the density file. What did you use to make your images? Hint: programs like Nero don't work.
                    I'm not using an image of RC, it's my real CD won't work as long as D-tools is on the comp.
                    • #11
                      You did not reply the questions Copytrooper asked you:
                      1. Check if it works if you enable SecuROM emulation.
                      2. Do you have AnyDVD installed?
                      • #12
                        Yeah my bad sorry, i tried it with each of the emualtions options seperate and together and the dang thing s still want s the real CD, but thansk for all you guys help
