I need to back up some MSDN subscription discs onto my business file server. Some of the discs are bootable, and some are dual-layered (guessing based on capacity).
What software is good for imaging DVD-ROM discs (not movies)? Do these discs need to be decrypted like DVD movies? How can I tell which discs need to be imaged and which discs are OK to drag-and-copy the files from? Are MSDN discs known to use any form of copy-protection?
