Just installed v1.2 patch and I get the message "Conflict with Disc Emulation Software detected". I tried modifying the driver ID but didn't help. Not sure what version of SecurROM is being used. Obviously the CD itself hasn't changed.
DuesEx:IW v1.2 new anti-emulation
Did you try to un-install Daemon Tools and use alternative names for bus- and miniport driver? Ensure you don't have any other virtual cd software installed (e.g. CloneCD, Alcohol ...). Also disable AnyDVD if you use it!
If it still fails, contact support@daemon-tools.cc.Everybody be cool! You, be cool!
@,jACkdA\W: Funny enough no, it worked without it and I might be mistaken but it even worked after turning the securom emulation off :? but ive checked the DVD with A-Ray Scanner and it detected Securom 5.00.03.0011...weird. Don't know if its worth mentioning but my copy is already at v1.2.
hmmm... probably drive-dependant. 'normal' read gave 74% quality or something like that, not enough; but (luckily? is that english??
) that was a friends drive not mine...
well i may be mistaken, but i don't think any sort of DT emulation is needed or would even be asked for if Blindwrite is installed, it emulates that on its own...but it even worked after turning the securom emulation off_____________________________________
