Game not working
  • Game not working
    Hi, I'm new here and I got a problem with playing High Heat Major League Baseball. I mounted the image file on a virtual drive with Daemon and I installed it. When I try to play it it says please insert the correct cd-rom. Anyone know the problem?
    AFAIK it's SafeDisc2 protected, so you've to use appropriate image (e.g. Alcohol or Blindwrite image). What kind of image did you try, and how did you create it (program & settings used)?
      It was a .cue image file, I don't know the settings (sorry if that causes any inconvience) I mounted the image file with all the emulation options turned on and what did you mean by AFAIK? Thanks in advance
        AFAIK = As far as I know
        bin/cue image won't work - recreate from your original in appropriate image format.
