WarCraft3 backup
  • WarCraft3 backup
    is it possible to use cloneCD to make an image for WarCraft 3 ?
    if not which burning progam do i have to use?
    does the same apply to Frozen Throne/Star Craft?
    WC3 ROC yes, TFT NO - WC3 ROC uses older subchannel based SecuROM, so CloneCD backup will work fine, TFT uses newer SecuROM, so use either Alcohol or Blindwrite image.
      i have discovered that Frozen Throne will work with the original Warcraft 3: Reign of Choas cd (or copy);
      so if you can make a backup copy of that you won't need the Frozen Throne cd to play.
        I dont know why but i made a clonecd image of frozen throne (before i knew of alcohol 120%) and it works off of d-tools. Was this some random chance?
