What is this?
  • What is this?
    Hello!
    In a burner program, close to all of them, I can read DAO, SAO, RAW and SUB and there are combinations of them.
    Can anybody explain to me what that is and what settings to use for best result?
    Well, those combinations called burning methods are the methods to burn :P You know... ehm when u're using a default burning prog ehm... blindwrite or somethin like that u will be able to choose dao pq and dao pw, those burning methods are currently the best ones.
    Have phun making the backup copies ;P
    DON\'T STEP ON GRASS, SMOKE IT!!!
