i made an CCD image from harry potter and the prisone of azkaban (danish version)
i can emulate the image fine without errors.
but if a burn the image to disk it will not start the game
I have read the iamge with Alcohol 120%.
burned the image to CD-rw with Alcohol 120% with the EFM options on and off.
Tried with cloneCD with EFM option ignore/amplify/emulate.
nothing helps
I'm tried reading the disc's on 2 diffrent machine and 3 different drives (2x cd-rw and 1xdvd) i tried using cloneCD's hidding CD-R media.
The load sekvens just stop and read alot on the CD until the game ask for the original CD.
emulating from the same CCD-image work fine without settings any extra options in deamon tools.
how do i burn this ?
Safedisc - 3.20.20
nothing helps
Safedisc - 3.20.20
