Hi, great program, but I'm having a bit of a problem. I installed "The Lord of the Rings: The Fellowship of the Ring" onto my computer from an image, and it installed just fine. However, now that I try to run it, whichever cd image I mount, I am told it is the wrong one. CD two is entitled "FELLOWSHIP_PLAY", and the other "FELLOWSHIP_INST", so I am fairly sure this is the one I should load when I try to play. Any thoughts as to how I might try to run it?
Game says wrong cd
