My CD for TFT was starting to get scratched, so I made an image of it, .mdf/.mds files. And it used to work perfectly every time. But now it sometimes decides that I don't have the CD in the drive. If I restart my computer, it will run again. If I close wc3 and then try to open it again, it usually won't work. Other times, when I feel like playing, it also won't work. 30 minutes ago, it said it needed the CD in the drive, but when I tried just now, it worked again, nothing changed. Any ideas on what's going on?
WC3:TFT problems
yea I've just recently (today) got that problem on my 2 computers that I use to play battlenet with. On one computer I use daemon tools. On the other computer, I use alcohol emulation problem. However, both computers use the same image (created from alcohol) and till now, both work fine (though the one using alcohol's emulation tools slightly more effective - ie less times showed randomly the "please insert cd box").
Is this because of a new battlenet patch that is identifying that I'm using an image rather than the cd (since both were working fine before)?
Do you think I should try re-imaging the cd and retry mounting it with a new image?
