Hello! I'm new and is not many weeks i use this great tool.
I run a reg. cleaner and after that the tool did no longer start because did not found the language to use.
So I reinstalled.
The problem is that now I have the 2 DVD roms I was using before showing in my Explorer. One of them has a game mounted. I try to unistall them but windows finds them again.
How do I unistall them permanetely? They are useless as Daemon does not work with them any longer.
Of course I can use anyway Daemon normally, but those other 2 roms are there and I don't like them.
Thanks for the help.
Regards to the forum
So I reinstalled.
