Tribes has the same problem as SW: Battlefront... use latest alcohol, make a Securom 4/5 then use dpm at 1x, the image mounts w/ d-tools, but its gets the ususal emulation software detected, ive heard that making an burned copy, then makeing an image from the copy instead of the actual may work... i will try that...
Tribes Vengeance
