Hi ,This is my first time post here.
I have read posts in the forum about ut2003 and noticed the focus is how to make the dumped image work.But the problem I suffered is that I CANNOT DUMP AN IMAGE.
My UT2003 is a localized version distributed by a local Infogram branch in Taiwan.This is why I suspect they may add something to the copy protection.I used the clony tool and identified the disk is securom 4.8 protected.But on disk 3,there is a significant strange track obvious to human eyes and it maybe prevent my Alcohol 120 to do a DPM. I left to sleep when the dump progress stopped at 85% and when I waked up 8 hrs after,it was still 85% and the cdrom drive seems out of function :shock: .
Is there such a strange track on your original version of UT2003?Or is this just due to my misunderstanding and mis-operate? :oops:
Thanks for your time reading this,and I appreciate if anybody can tell me about the oringinal version of UT2003.
I use Alcohol 120% V1.36.1223 with Securom 4.x new settings.Tried both my TEAC 540E and SONY CRX140S,The same problem encountered.
