I originally asked this in the general support part of the forum maybe this is the right place
sorry if this is a dumb question!
I have 10 bin files of CDs I want to put onto 2 DVDs.
I mount the bin file using Daemon and can play the file locally.
But I can't copy or save this file onto the hard drive.
I get error 'cannot copy (filename) the parameter is incorrect' from windows explorer and if I open the file in media player (it's an MPG) and then try to save it the same problem occurs.
I normally use isobuster to do this but it failed to open up these bin/cue files.
thanks in advance...
I never have problems doing this normally. I feel like a newbie again!
