Writeprotected driver
  • Writeprotected driver
    Hello, i`ve got a problem.
    When i try copy files into the driver which i`ve mounted, it says that the files on the driver are writeprotected.
    But when i try to remove the protection, i can`t because i "have no access".
    What to do?
    did you ever try to write to a CD-ROM?
    What's the difference here? Yes, nothing. That's the reason you can't
    modify files. Daemon Tools is a CD/DVD - ROM(!) - Emulator, not a
    CD-Writer-Emulator.
    And why do you try to remove the protection? Which game?
