First of all an installation issue...i start installing it goes fine, then it comes up with new hardware detected (XP thing) and it says it cannot install the SCSI controller...the Deamon installation completes fine, but it says "Your hardware was not installed properly" etc. Will this be a problem when running deamon?
Bit new to all this...
