I did a search of the forums, and it said to use the original war3 disc. Well, you cant exactly run TFT (expansion) with the original disc. I have both of the images of the discs mounted, with all emulation options enabled. "Inset disc" is what I get when I try to play. I'll be on AIM all day, its "xiihacLx" or "angryangel401" if you think you could help me out right away. Thanks.
War3 TFT
To tell you the truth I didnt copy it myself -- I cracked my CDs so I had my friend who i play with on bnet to send me an image. Like everyone here I actually OWN the game(yes i bought it and have original cdkeys), i just cracked the cd and dont feel like paying 30+ bucks for another one... so what options do I have? thanks.
you can use n*-* patch or you can created yourself your copy ...
if my memories is good , warcraft 3 is protected by securom 4.8* so use alcohol whit securmo new 4* / 5* profil... and when you mount this images files in daemon , normally , it will work fine
Re: War3 TFT
Well.... I could run the Wc3 TFT with the normal CD, have you tryed it?? And you can download a "No-CD" for the newest version, the only bad thing is that you have to debug the .exe everytime there is a new patch.Originally Posted by cyrus221I did a search of the forums, and it said to use the original war3 disc. Well, you cant exactly run TFT (expansion) with the original disc.
