I wish I were'nt such a newbie,but this is my problem.
Ive tried using Games Xcopy to burn RTWD1,(play disc)but it wouldnt work. I would get up to the loading screen,but it wouldnt go into the game.
I gave up after 20 coasters.
I updated my Daemon tools to the newest version,and installed Alcohol 120%
I tried again,(with 120%)it took forver and a day to get through the first 5% or so and then it moved along rather quickly.I had the daemon tools set to safe disc(looked in the database),still no luck.
I used my Samsung DVD-sd-616e rom player to read it, and my memorex 52Maxx to burn it.(I also have a NEC-DVD+rw burner)
Im not sure if I need any more info that would be helpful,but this is part of the text file that was made after it was done.I hope it helps:
19:52:15 Processor info: Intel(R) Pentium(R) 4 CPU 3.20GHz x 2 (3192MHz)
19:52:15 Memory Available to Windows: 2,096,108 KB
19:52:15 Memory Buffer size: 128 MB
19:52:16 Image file loading: C:\IMAGES\Rome_TW_CD1.mds
19:52:16 Source Info: Session: 1, Track: 1, Length: 565.7 MB / 064:22:06
19:52:16 (G
Memorex 52MAXX 3252AJ(USB:0): Recording Method/Speed
19:52:16 Recording - DAO / SAO - 52X (7800 KB/Sec)
19:52:17 (G
Memorex 52MAXX 3252AJ(USB:0): BURN-Free activated
19:54:12 Image file loading completed!
19:54:30 (G
Memorex 52MAXX 3252AJ(USB:0): Recording completed successfully!
19:54:30 Elapsed Time: 00:02:13, Average speed: 30.4X
19:54:34 All recording procedures have been completed!
19:54:34 Elapsed Time: 00:02:15
The options I chose in the copy wizard:Skip reading errors, fast skip error blocks,read sub-channel data. My write speed was set to max,and I checked buffer underrun.My data type was set to customize,as I didnt see a safedisc option.
If anymore information is needed,just post and let me know.I dont know if I didnt choose a proper option,or if Im just cursed.
Please help,(sorry im such a newb)
Darksygil
19:52:16 (G
Memorex 52MAXX 3252AJ(USB:0): Recording Method/Speed19:52:16 Recording - DAO / SAO - 52X (7800 KB/Sec)
19:52:17 (G
Memorex 52MAXX 3252AJ(USB:0): BURN-Free activated19:54:12 Image file loading completed!
19:54:30 (G
Memorex 52MAXX 3252AJ(USB:0): Recording completed successfully!19:54:30 Elapsed Time: 00:02:13, Average speed: 30.4X
Darksygil
