Hi, I"m extremely new so please forgive me. Everything about daemon tools, etc is new to me, but I have been trying to figure it out. I am trying to copy a video game from 2 .bin files each of which represents the 2 cds of the game. When I mounted the .bin files with DmTools, the installation process went through, asked for cd2 and everything went well. And as I see is a common problem from the FAQ/Troubleshooting, when I go to run the program, cd1 works, and then asks for cd2 whereupon an error message tells me to insert the correct cd-rom, select ok and restart the application.
According to the faq guide, I tried running the program again under drive f of Dtools, ejecting after cd1, then mounting cd2 in the same drive. No dice. So, I tried to burn the .bin files on to cds using CloneCD and choosing Write from Image File. I burnt both .bin files onto 2 separate cds, but when I check the contents of the cds under windows xp, no files appear. When I insert cd1, nothing starts up, and there is no boot file to click. When I try to mount the image from the e-drive, there is nothing to mount. So this is where I am now.
Does anyone know what I'm doing wrong?
