Hi Guys, I have an iso image of LSL:MCL on my hard drive and i wanted to know how exactly i can make it work using DAEMON tools.
Help with Leisure Suit Larry:MCL
This topic is closed.
I have tried to understand and do what has been mentioned but I have not been successful.
Could somone please explain how I can get this game to work. I have all four Leisure Suit Larry bin files and cue files, and I have even installed the game, but when I try to use Daemon to load the game, it says that I have the wrong disc.
I have tried to use alcohol, but I could not understand what yall were talking about. Please help me step by step to get this to work.... :?
What program (and settings if you remember) did you use to create the .bin/.cue files?
Try re-creating the images from your CDs in Alcohol's native format. First you need to find out what protection the game uses (use a protection scanner on your original CDs or Google for it) and then use the appropriate profile in Alcohol.Win2k3 & OSX Intel, 2GB DDR400 P4 2.6@3.55 H2O, 7800 GTX @480/1250 H2O, 1x74GB Raptor, 8x400GB RAID5
