I have been testing all of the software out there and cant seem to make a perfect 1:1 copy of my games. I dont know if it is my cd burner or the discs i am using. I have a samsung burner and i am using maxwell cds for my blanks cdr-s. So i was wondering if anyone out there could help me with this stuff. Thank you very much.
Help with making perfect images of games...
The model number for my cd-burner is a Samsung CDRW/DVD-SM332B. It is an all in one cd burner. I am currently using alcohol 120%, i made some images for the games that i wanted to back up, i ran them and they ran fine. But then when i tried to burn it onto a blank disc, then the program froze. I am trying to back up my medal of honor allied assult and spearhead. I am using maxell cd-r 700 MB. I hope this is enough info for you.
I have not tried to close all of my background programs, ill try that. But why does the image work fine but then the disc i just burned not work. I turned all of the emulation stuff off and it still works fine. Is my image a 1:1 copy? Is my burner good to do these kind of things? What blank CD-Rs should i use? I have easy cd creator, but it wont work with maxell cdrs. Should I try a different brand? If you could help me that would be great.
first off, easy cd is evil, and you should not use it; uninstall it!
if the image works with d-tools (no emulation);
then it is probably 1:1. goto www.gamecopyworld.com and lookup the copy protection. perhaps something is messed up with your burner or windows? try maybe uninstaling some things.
