Warcraft 3 plugged in daemon-tools; Insert CD message
  • Warcraft 3 plugged in daemon-tools; Insert CD message
    I can't seem to get Warcarf 3 to work...
    Assuming I don't have a problem with the ISO, what could it be?
    I tried the safe way with DTOOLS; ejected all CDs in other drives, I disabled them in XP so the letter doesn't exist. I ended up with 1 CD drive made by DTools. I select image in DTOOLS, enable SecuROM and still no luck....I tried burning the ISO with NERO (lol);
    but it's still not working....
    Anyone has any suggestions please?
    Thanks
    why do you have an iso. If you downladed this, know that yuou won't get any support? to make a perfect backup, use alcohol 120 or ******** to make the image off the ORIGINAL disc.
