Problem with severance!
This topic is closed.
  • Problem with severance!
    Hi there!
    I'm Mike and i have a problem with Severance: blade of darkness: I have a perfect 1:1 raw image mounted with DAEMON and also
    installed from this image but the program still requests "wrong disk"! it also checks in all the drives and when arrives at the phantom, says "wrong disk"!
    Somebody can help me?
    I've performed all of the listed operations for the securom new burning with alcohol 120%, i tried too with the preset of securom new 4.x/5.x, but it doesn't work...
    What can i do?
    Thanks a lot and bye!
    Win xp sp2,
    alcohol 120% 1.9.2.1705
    Severance is protected with OLD Securom *New*
    You must read the Subchannel-Data, too
    Which program was used to create the image and which settings?
      hi,
      to create the image file, i used alcohol 120 % 1.9.2.1705 with preset settings for securom "NEW"...
      i also tried with securom "new" 4.X/5.X settings, but it still doesn't work!
      subchannel data reading is ON in these two settings, but it was unuseful!
      Thanks, bye
        JBTW: don't know what version you got. you did do a protection check?
          the protection is securom "NEW" v. 4.32.00.0002...
          It 's the same of Neverwinter Nights...maybe...
            Someone help me please!!! :cry:
              Works fine for me from image even with installation from cd.
              Try to re-create the image from original cd with lower read speed.
                i tried so many times... :x
                Can you describe me how did you make it?
                maybe, a little tutorial for me? :lol:
                Thanks! :wink:
                  What? Standard procedure:
                  Installed from cd, created image with Alcohol, ejected cd, mounted image, started game -> works.
                    I HATE YOU!!! :twisted:
                    I did everything you said, but it doesn't work!!! :cry:
                    i have more details for you:
                    I installed severance from a backup disk, with a fixed exe...that works only with win 98, now i'd like to play with win xp! I tried, but i failed...
                    So, my source disk is a backup disk, is this a problem? Should i have the original cd? I lost it... :oops:
                    cd/dvd burner LITE-ON DVD-RW SOHW-1633S
                    cd/dvd reader LITE-ON DVD SOHD-167T
                    CAN YOU GIVE ME SOME MORE INFORMATIONS?
                    Thanks! :lol:
                    • #11
                      learn to behave like a human being!
                      beside from that, you should learn to read our site-rules next time
