Yes,got both working but I can't find an easy to understand guide.I want to copy an ISO file of an english dictionary from longhorn called LDOCE.Have tried doing the best I think it's OK,with no results at all.can you guys please help me?.Also try to setup Daemon 347 but all I get is window saying something about drives.
Got Daemon T 344 and Alcohol 120,NOW WHAT DO I DO !!!
Got it!!!.Thanks.My main concern was that after the Image installation, which archive should I use to burn,the Image on virtual drive or the original file on my Drive.Did it with original file and worked perfectly.Any way,is there a tutoring file for Daemon anywhere ?
Thanks for your concern.
leavanni, I would appreciate it if you would post the exact error message you get upon attempting installation of Daemon-Tools 3.47.
It will decompress to a temp folder (I doubt that is the problem though), you might want to check the disk space and permissions on that.the modern world:
