Imaging Software:
Alcohol 120% Version 1.9.2
Virtual CD software:
Daemon Tools 3.47 (r0x0rz my s0x0rz)
Other tools:
DaemonScript 1.5.4 (also r0x0rz my s0x0rz)
Okay I've been using the mighty Alcohol/Daemon tools/daemonscript triad for all my games. I love being able to play em all, without having to insert any CD's, and automounting em using daemonscript... its so t3h convenience :p (my gf got me hooked on dumbass l337sp34k so bare with me)
Anyway I haven't had any problems so far (recent games I play are Farcry, Doom III and nfsu2)... I basically just check with daemon tools game database; make image according to the protection, make a daemonscript to:
-unmount
-mount image
-emulations (uncheck them all)
-runapp
Then create a shortcut to automatically mountandrun the game
It worked every time... but now this one game: Chronicles of Riddick: Escape from Butcher Bay, is giving me trouble.
I have the CD version (not the DVD version).
So here's what I did in this case:
- Installed the game (full install with all t3h g00dies)
- Made image of 1st CD using Alcohol 120% using the 'Securom New' data type
- created my uber deamonscript
- tested it... it didn't work
Instead the lil riddick launching icon flashed, and then I got this error message:
Conflict with Disc Emulator Software Detected. See www.securom.com/emulation for more details (click okay)
Then if I try to test again (or run any other game that needs daemon tools) I get this error message first:
Error on line 2:
Unit Locked
Would you like to continue execution
(click yes to continue anyways or no to cancel)
The other games run fine, despite the above error message; but it bugs the hell outta me, and the only way to unlock the unit is to reboot my pc...
I would like to note that the game runs fine with the original CD in the drive. No need to uninstall anything, or play with any fancy settings or watever... it works fine
I would just like to run it without needing the CD... Cuz playing ur games without the CD is l337... plus it keeps the CDs nice and scratchless...
Any ideas on how to get this to work? What I've done so far is pretty straight forward; and have never had any problems prior to this game... And I'd like to keep it straight forward (pls no backwater patches or anything like that, I loath patches)
Thanks for the consideration.
Other tools:
-unmount
-mount image
-runapp
Error on line 2:
Unit Locked
I would just like to run it without needing the CD... Cuz playing ur games without the CD is l337... plus it keeps the CDs nice and scratchless...Any ideas on how to get this to work? What I've done so far is pretty straight forward; and have never had any problems prior to this game... And I'd like to keep it straight forward (pls no backwater patches or anything like that, I loath patches)
