I saw, there are virtual drives in alcohol, and there are only 5 virtual drives in Daemon. If I use more than 5 drives, which should I use, Alcohol or Daemon?
Daemon Tools or Alcohol
I dont think that Alchohol can supprot more than 3 drives. I remember some time in the past when I was mounting on multiple drives but I got SO many errors :shock: . Its not even funny. That happened with Alchohlol and Daemon-Tools. But back then I was running on w9x... Anyway why dont you download the trial of Alchohol and post you're results here?Failure is the mother of success.
No other software available enables you to create up to a staggering 31 virtual drives, allowing you to run your game images at over 200x faster than from a conventional CD-ROM. Alcohol 120% is a powerful utility that uses a unique combination of options to ensure a perfect back-up every time.
Source
Cheers
