I'm fairly new to this and I need some help. The question is as follows; Can I copy Flight Simulator 2004, which has 4 CDs, to my HardDrive then make an image, and mount that image so that the game loads from it. If I can can some one tell me how? Thank you
Game Images
You can't make an image of the game itself; only from one of the CDs; proceed like this :
- Install the game
- lauch the game and see witch CD is needed.
- Check the copyprotection kind in the "Database" section of this site
- Download and install Alcohol 120%
- make an image of the game CD using alcohol, and the settings according to the game database
- download and install daemon-tools
- mount the image created by alcohol in daemon-tools' drive
- lauch the game
et voilа
Re: Game Images
Hi from ROBO do i understand correctly you would like to make one imageOriginally Posted by julvazI'm fairly new to this and I need some help. The question is as follows; Can I copy Flight Simulator 2004, which has 4 CDs, to my HardDrive then make an image, and mount that image so that the game loads from it. If I can can some one tell me how? Thank you
for four cd's
regards ROBO
