cue sheet line 1-file not accessable
  • cue sheet line 1-file not accessable
    Can't mount an image, allways got the same message: cue sheet line 1-file not accessable!!
    What should I do???
    Thanks for your help
    javascript:emoticon(':wink:')
    Wink
    What kind of cd (data, audio, game), and how did you create the image (software and settings used)?
      Its a DATA CD no idea about the software used to create the imege.
        Post the contents of the cue-sheet then.
          How can I get it, I always have an windows error message only?
            The cue-sheet is a plain text file, just open it with e.g. the Windows Editor and copy'n'paste the contents here.
