i downloaded daemone tools and i mounted medal of honor and installedthe game. but when i click on the iccon to play, it says-- please insert the correct cd-rom.-- can someone plesae help me?
help me please.. cant start this game
repeat mode on
how did you create the image?
which software did you use, which settings?
which format is the image?
is clonecd or something like this running?
if the image wasn't made by yourself or if you used the iso-format, then please read the boardrules and/or use the searchfunction.
repeat mode off
