Hi!,
I have made cd images of the above mentioned games using Alcohol120% and / or Blindwrite. I mount the CD images over a network and start the installs.. it goes well up to the point when it asks for the second CD.. I mount the second CD by right clicking on the D-tools icon --> "mount image".. and select the second CD image. Then I click ok to continue with the Installation but it just keeps asking for the second CD. If I use windows explorer to check if the CD is actually mounted I see the contents of the second CD.
If anyone can shed soem light on this issue it would be greatly appreciated.
Thanks,
Dan
Thanks,
Dan
