I am trying to run this game sid maiers pirates i mounted the iso using DT and now i get this message"Conflict with disc emulator software detected. See www.securom.com for details" Can anyone help explain this and what i need to do to fix this? your helps greatly appreciated.
Sid Maier's pirates emu problemo!
First, create the CD image using Alcohol or Blindwrite
Next, launch regedit, and modify (at your own risks) the registry :
1 - Deny read access to Administrator user on the key HKEY_LOCAL_MACHINE\HARDWARE\DEVICEMAP\Scsi\Scsi Port x
where "Scsi Port x" is the key where you can find the value "Driver"="d347prt".
For me, it's "Scsi Port 2", but it may change depending on your scsi devices.
2 - Deny read access to Administrator user on the key
HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices
Next, play the game.
Yess, Amen brothers and Sisters thanks for the great replies only other thing i did was changed the virtual drive properties and that was it. Ok so now where can i read some good info on editing the registry and why and what exactly did i just do ? Id like to understand this a little further!
Thanks in advance
Broman
What i told you is just a compilation of this forums. So open your eyes and browse ! :mrgreen:
Look at this Thread http://www.daemon-tools.cc/dtcc/port...pic.php?t=5492 . Here is a tool that does the registry trick automatically.
which image???
Post Qoute:
"ISO is an obsolete format that doesn't contain enough information to work with modern protected games, re-create the image(s) from your original CD(s) using Alcohol 120% or blindwrite 5."
Alcohol gives options on what image: .iso, .ccd...etc etc
so which format should you use?
Also what Datatype should you use?
