Howdy
I have downloaded a beta version of OS X Tiger (Mac OS) into my windows pc.
The format of the files are .dmg
I read in a post somewhere that I could use deamon Tools to mount or burn the dmg files in my pc.
I have Nero 6 and Alcohol 120 Corporate on My Pc
I have read that it is no good converting the dmg files to ISO and burning, as a Mac wont read the burnt image.
What I am basically trying to do is set up this Virtual machine in my pc. The Virtual Machine Emulator is called PearPc. This is a open source software that apparently gives u the ability to run a Mac Operating system within a virtual envirement, on a Windows XP machine, much like VM Ware.
I just want to have a play with a Macintosh OS in my PC. I believe PearPC is the ticket, But dealing with the .dmg file is the problem. Unfortuanately I dont have a Mac to burn the file to disk.
I dont know if what I am trying to do is possible, with the resources I have availaible. I have a P4 3200 Prescott, GA board, 1GB RAM, LG DVD dual layer burner - but no Mac.
I have downoaded the Daemon 347 exe and am just about to install it.
Any help would be apreciated. I am reasonable with pc's but i dont have any experience with Daemon Tools or Mac's.
Thanks
Thanks
