I get a "Please insert CD-Rom"
  • I get a "Please insert CD-Rom"
    Operating System: Windows XP Pro 2002 w/ SP2
    Burning Software: CloneCD, Alcohol 120%, Games X Copy.
    Anti-virus Software: PC-Cillin 2002
    DAEMON Tools Version: v3.47
    Hello everyone.
    I have a problem with my Daemon and/or any virtual drive. When I create an image via CloneCD or Alcohol 120% and try ti play it in Daemon v3.47 I get a "Please insert CD-Rom". Anyone know how to fix this. I have tried it with differant games and it always ask for the game disk. I mostly try Need for Speed: High Stakes. If anyone has any info please help. Thanks.
    You probably need to install it from the virtual drive and/or to play from lowest drive letter.
    NFS-HS is really old, so CloneCD image should work fine.
    It's also possible that you need to apply the SafeDisc patch available for WindowsXP.
