The Incredibles - When Danger Calls - Not Working.
  • The Incredibles - When Danger Calls - Not Working.
    Operating System: Windows XP SP1
    Burning Software: Nero 6.03
    Anti-virus Software: None
    DAEMON Tools Version: 3.47
    Hi.
    I have a couple of questions...
    1) What level (revison) does this version of Daemon Tools support?
    2) I try to burn an image onto my hard drive of this game, but I get read errors due to the securom protection 5.03.xxxx.xx of the game.
    What can I do to make it work under DT 3.47.
    Detailed help would be appreciated.
    TIA :?
    this board is EXACTLY to help people to help others!! All the answers are there,
    you only have to read them.
    DT supports SafeDisc and Securom near perfectly, only for latest protections
    (read somewhere at the board, use search function to find out WHICH
    protection your game exactly is protected with) you maybe have to use
    some 3rd-party stuff or registry-manipulations. In case of Securom there
    are already several threads about it!!
    How did you created the image? which settings and which application was used?
    BTW: Securom protection does not contain any read errors. Where did those
    errors occur (sector-numbers)?
