I'm creating an image of Morrowind with Alcohol 120%. As you know, it's Safedisc 2.90 protected. I've followed the instructions on how to use the fastdump method, but Alcohol still doesn't skip the errors. What could I do to make it work? Or does my laptop only have a DVD-RW -drive that doesn't support fastdump?
I can't get Fastdump to work!
With some titles* (or drives ?) fastdump method still works. What does this depend on ?Originally Posted by CopytrooperFast dump does not work with SD2.9x and newer versions anymore.
* only tested Doom3 and PariahI'm not employed by Disc Soft and my views do not necessarily reflect the ones of the company.
