Hi
made back up images of educational software i own , all use to work fine with dt , but now i keep getting asked for the cd ??? on 4 of them , the other one , tries to laod and giveds the error = macromedia flash has a problem and has to close , the other 2 work fine ??
i apologise for the lack of info but if you tell me what info you need to solve this i will get it for you
the only thing i can see that looks like it a protection thing is SECDRV ??
THANK YOU :idea:
THANK YOU :idea:
