I almost never burn unless I have a problem with the cmoputer so I always use DT. I really don't want to test it right now because installing d2 takes forever, the install is really annoying. Thanks a lot for your help and I guess I'll come back when the new patch comes out
Diablo 2 Asking for CD
Strange. Try to create a backup (e.g. on cd-rw) with Alcohol using SecuROM new profile (i.e. NOT SecuROM new v4.x/v5.x profile!), check if it works from image, if it works ok write to cd-rw - ensure you write in RAW-DAO96 mode with Rectify subchannel data option NOT checked (should be autoselected by using SecuROM new profile during write in Image Burning Wizard).
Btw which writer do you use? Is it able to write in RAW-DAO96 mode?Everybody be cool! You, be cool!
copying Diablo II game
I have a feeling your drive cannot read subcodes.
These are questions for anyone: Diablo II LoD expansion uses SecuROM 4.85.07.0171 but what version of SecuROM did the Diablo II CD use before any patches were released? And does fast dump work for some versions of SecuROM? Could that help TylerDurden in this case, seeing that he may not have created an image with the proper subcodes (of course SecuROM emulation option should be ticked via the tray icon)?the modern world:
Just use Alcohol's Image Making Wizard, SecuROM new profile and wait untill the image is created, then remove the cd from your real drive and mount the image to the virtual one. Don't forget the drive letter problem. Check if it works from image.Everybody be cool! You, be cool!
