Hi all,
Here is the situation;
I have taken the bin cues and extracted them-- their are two disks and somehow I did not burn them correctly---and have dumped the bin files but still have the setup files (both cd's) on my hd...My cd disks that i burnt them too never worked because it would tell me to put in disk two.. once i did that...it would still come up with it...how can i run the setup files from my hd, (as the cd's dont wrk) and have the program recognize where disk 2 is so that the install will wrk?
any help would be great
thanks
Sig
thanks
Sig
