StarForce 3.0 Please !
  • StarForce 3.0 Please !
    How it crack?
    All Virtulas CD Program no work with tjis Protection!
    afaik, D-tools can work with this protection. You have to make your image with alcohol 120% or gamjack. You must used mds information in alcohol (don't know what it is called in ********). Then you can play your image...
    If you want to make a backup, you can burn with RMPS in alcohol and enable RMPS emulation in d-tools.
    What game specifically doesn't work?
      Alcohol 120% may crack only StarForce 1.0/2.0
      ******** may crack StarForce 1.0/2.0 too!
      The Game Name - "American Conquest" Russia Version
      With Protection StarForce 3.0
      English Version have protection SafeDisk 2.0 =>
      NOCD Patch for English and German Version no work!
      English Version i don't see in our game-shops
        english version is securom.
          I seem to have the same problem with starforce 3.0.
          I created an image of the game I wanted to play. But when I use Daemon tools to mount it, starforce says I have to put it into another drive.
          A friend of mine said I have to disconnect my CD-rom drive, that is, I have to pull out the IDE cable connected to my CD-ROM.
          But I tried and it didn't work, I also tried to disable my CD-ROM through systems, but still didn't work.
            What's the name of the game? How did you create the image?
              yes, gamejak and alcohol do not support this protection officially.
              But alcohol can make a working image.
              Then mount it on alcohol o d-tools virtual drive
              Starforce will ask you to put the cd in another drive (because the virtual drive is SCSI). Then you have to disable/unistall all the IDE drives like CD/DVD-ROM and/or CD-R/RW and/or DVD-R/RW/+R/+RW. Then it will work
