I could not copy a DVD containing a concert performance on to another blank DVD disk using CloneDVD and AnyDVD. The error message on CloneDVD says it does not know the format of the source DVD disk.
For your information, I paste a file listing of the source DVD disk below.
Volume in drive F is TDK_NEUJAHRSKONZERT_2002
Volume Serial Number is 4A05-F982
Directory of F:\VIDEO_TS
01/30/2002 03:07 AM <DIR> .
01/17/2002 07:03 AM <DIR> ..
06/30/1974 05:00 PM 0 VIDEO_TS.BUP
06/30/1974 05:00 PM 0 VIDEO_TS.IFO
06/30/1974 05:00 PM 0 VIDEO_TS.VOB
06/30/1974 05:00 PM 0 VTS_01_0.BUP
06/30/1974 05:00 PM 0 VTS_01_0.IFO
06/30/1974 05:00 PM 0 VTS_01_1.VOB
06/30/1974 05:00 PM 0 VTS_02_0.BUP
06/30/1974 05:00 PM 0 VTS_02_0.IFO
06/30/1974 05:00 PM 0 VTS_02_1.VOB
06/30/1974 05:00 PM 0 VTS_03_0.BUP
06/30/1974 05:00 PM 0 VTS_03_0.IFO
06/30/1974 05:00 PM 0 VTS_03_0.VOB
06/30/1974 05:00 PM 0 VTS_03_1.VOB
06/30/1974 05:00 PM 0 VTS_03_2.VOB
06/30/1974 05:00 PM 0 VTS_03_3.VOB
06/30/1974 05:00 PM 0 VTS_03_4.VOB
06/30/1974 05:00 PM 0 VTS_03_5.VOB
06/30/1974 05:00 PM 0 VTS_03_6.VOB
06/30/1974 05:00 PM 0 VTS_03_7.VOB
06/30/1974 05:00 PM 0 VTS_04_0.BUP
06/30/1974 05:00 PM 0 VTS_04_0.IFO
06/30/1974 05:00 PM 0 VTS_04_1.VOB
06/30/1974 05:00 PM 0 VTS_05_0.BUP
06/30/1974 05:00 PM 0 VTS_05_0.IFO
06/30/1974 05:00 PM 0 VTS_05_1.VOB
06/30/1974 05:00 PM 0 VTS_06_0.BUP
06/30/1974 05:00 PM 0 VTS_06_0.IFO
06/30/1974 05:00 PM 0 VTS_06_0.VOB
06/30/1974 05:00 PM 0 VTS_06_1.VOB
06/30/1974 05:00 PM 0 VTS_07_0.BUP
06/30/1974 05:00 PM 0 VTS_07_0.IFO
06/30/1974 05:00 PM 0 VTS_07_1.VOB
32 File(s) 0 bytes
2 Dir(s) 0 bytes free
You may note that each of the files contains 0 byte. This sort of file listing structure is similar to the file listing of a CD audio disk.
Please could you tell me how to solve this problem or if I can use DVD Shrink to rip it instead. I also used PowerDVD to play the DVD disk, but it says the disk is not of a supported type.
32 File(s) 0 bytes
