Max Payne 2 problems with Daemon tools
  • Max Payne 2 problems with Daemon tools
    Operating System: Windows XP Home Edition
    Burning Software: Nero, Alcohol 120% (Free trial), Blindwrite 5 (trial version)
    Anti-virus Software: Norton Antivirus 2004
    DAEMON Tools Version: 3.47
    I had just got some money and went to walmart and picked up a copy of Max Payne 2: The fall of Max Payne and Went home installed it on my pc, after I was done installing, I then created an Image of the play disc with first Alcohol 120% , then I mount it with daemon tools, My Pc acted like it was loading it (hard drive light was on) but after a minute the light stopped blinking and nothing appeared on the screen. It works fine with the actual disc in the tray though. I also tried burnin an image of it with blindwrite 5. If anyone can help me out Thanks ahead of time, otherwise I have to keep popping in the cd when I want to play.
    Xtemulation - Emulation News and Downloads
    Xtemulation Forums - Emulation Support
    Nevermind
    Nevermind I figured it out, I had to create an image with data precision measurment and now it works perfecty so you need not reply to this post, The admins can delete it if they want.
