I am running Windows XP. I am using an NEC 7900A 24x10x40 burner. I have created a .bin - .cue with CDRWIN of my Neverwinter Nights discs, however when I try to mount the Play Disc, it is not made available in My Computer. I am using 3.29. I have produced the image several times with no luck on mounting. If there is any other info I can provide please let me know. I get no crashes, installs fine, and the mounted image shows when I right-click on Daemon tools. I have Securom checked. I am at a loss. Please help if you can.
Thanks
PS - I get an error "Windows cannot read from this disk. The disk might be corrupted, or it could be using a format that is not compatible with windows."
Thanks
