Operating System: Windows XP Professional
Burning Software: none
Anti-virus Software: none
DAEMON Tools Version: 3.47
I installed games from several disks and some of them do not run giving me "Insert Disk" message. All of them are in .ISO format and have SecuROM protection. Regedit tells that the disk is in the correct drive. Is there any way to fix this? Could it be because of incorrect copying from disk? Would burning (alcaholing) it on a real disk work? And why some disks work and some don't?
