Hi guys this stuff was probably asked (and answered
) a lot of times but I think we need organize things a bit.
Making backup copy of StarForce using Alcohol
First we have 2 types of StarForce : with and without key (key on media?).
Then we have StarForce for CD and StarForce for DVD.
So here I will update and summarize your post, so far I know that :
- Uninstal StarForce drivers if installed using SF driver remover (link below)
- to create (any type?) backup you need to turn on DPM option (need to enable "ignore disk error" on CD ? on DVD ??).
Tools to use
- Alcohol 120% (http://shop.alcohol-soft.com/en/alcohol_info.php)
- StarForce drivers uninstaller ( http://onlinesecurity-on.com/downloads/sfdrvrem.zip )
- StarForce Nightmare ( http://starf.bestmedia.kiev.ua/ )
- SFCure - works to allow SFNightmare work with new versions of SF ( http://rapidshare.de/files/6036094/sfcure01h.zip.htmll - remove .html ext after downloading)
Is it correct , what are the other considerations ?
Is options listed above (keyed/keyless and CD/DVD) are the only "diversions" of StarForce or am I missing something ?
Let's together organize things a bit.
Another issue - how to play such copies ?
if I understend correctly even with good image file created as abouve you need to use SFNightmare and SFCure/ Win2k3Node disabler - is it correct ?
Anyway I think we also need to create a generic manual for using images too.
[b]Aperent order of orerations to play image[b]
) a lot of times but I think we need organize things a bit.Making backup copy of StarForce using Alcohol
Tools to use
