I deleted the double posts, the forums are partially moderated, which is why you didn't see your messages immediately.
So did you create new images with Alcohol 120%? Please do that and try it with those.
You could try to do a directory scan with Aray Protection Scanner (-> google), maybe the setup is copy protected too. Although this is uncommon, it is not unheard of - C&C: Red Alert 2 setup was copy protected, too. This is a totally wild guess though, it probably won't be the cause of your problem.
