Black & White 2
  • Black & White 2
    How do youy make a working backup of B&W2 (DVD-edition)?
    Tried alcohol and clonecd with no results, is it settings?
    Can anyone please help me??
    What hardware and what settings did you use in Alcohol for creating the image?
      You only have to make an image with Alcohol, you could enable the ignore read error option.
      Try using an antiblacklisting tool like SD4Hider (SafeDisk 4 Hider)
      cdmediaworld.com/hardware/cdrom/cd_utils_8.shtml#SafeDisc%204%20Hider
        B&W2 doesn't need anything special. Put the original DVD in the drive, make in image without enabling "ignore errors" and "DPM", mount it and play. Nothing more is needed. Even if you update the game (there's a patch), it will still work.
        You cannot burn the image to a backup DVD though.
          Thanks guys!Tried it without "ignore error" and now it works fine.
